Remove the 80 Character Barrier for String Parameters
Regular Member
Please remove the 80 Character barrier/limit in STRING Parameters.  If a String Parameter is allowed to be entered in PDMLink then it should be able to be as long as required.  Also Word Wrapping in Tables allows for longer text to be effectively entered but now the limiting factor is the 80 characters that is a max in Parameters.
Re: Remove the 80 Character Barrier for String Parameters
I would also like to have the capability to restrict the length of parameters.  I know this can be done in MC, but having something that prevents it in the first place allows quicker reaction times from the designer.
I am mostly considering parameters that may have downstream limits and since we send some parameter values to wt.Parts from CAD then those limits may or may not be imposed based on Business Rules at release.  If we can stop the cut from happening in the first place, we don't have to worry about applying the bandage, whether big or small.
