Rendering with a transparent decal
SOLVED
Highlighted
Newbie
Hi Community,
i try to add a decal with big letters on my part. For this i have made a transparent .png file.
Unfortunatelly I am not able to make this decal really transparent, because i must choose a colour.
Please see attached picture and I hope you will understand.
Thanks a lot for your help.
Andreas
Creo Parametric 2.0 | ARX Renderextension
1 ACCEPTED SOLUTION
Highlighted
Re: Rendering with a transparent decal
You use the image editor in Creo to set the alpha channel.
It is highly criptic but it does work if you guess correctly.
It is best to make the transparent color either fully black or fully white.
The file is saved as .TX4 to tell the renderer it is a 32bit file (w/alpha channel) IIRC.
16 REPLIES 16
Highlighted
Previous question went unanswered: http://communities.ptc.com/message/192346#192346
Photoshop for the win.
Highlighted
Highlighted
Highlighted
In WF5/Creo-Elements it is under Tools/Image Editor, next to Appearance Manager.
Highlighted
Creo 2.0 has made the editor more accessible: Upper right in the ribbon.
Highlighted
Makes you wonder what happened with .TX2, doesn't it
Welcome to the forum, Andreas.
Highlighted
For those not in on the joke, TX1 = 1 byte/pixel for a bump-map, TX3 = 3 bytes (RGB)/pixel for color, and TX 4 = 4 bytes (RGBA) for color + alpha/pixel. Not much uses 2 bytes/pixel, esp PTC, so no TX2, though some tools handle 3 floating point values per pixel, if your HDR needs are strong enough.
At least you got your wish for the Image tool button to be near the rendering tools.
Highlighted
Now that makes sense.
Highlighted
Hi Everybody,
thanks a lot, this was all really helpful. Finaly it works, but it was not easy. Much more complicated than in Solidworks.
A few things i want tell you.
- The alpha channel settings are hard to understand. To eliminate the white backround i have sucsess with these settings:
- Because I have a few surfaces in brushed metal without logo and one surface with logo I just copy the color "brushed metal" and add only to this copy the decal. So my Part now has 2 different brushed metal colors, one for normal surfaces and one for the logo surface.
I am sure, for this problem exist better solutions, right?
Have a good day and greetings from Germany
Andreas
Message from Brian Thompson (PTC General Manager and DVP) regarding Creo Business Continuity plans.
