Repeat Region Relations - AND/ORs
Newbie
I'm looking at a simple repeat region relation, one that will add a
"REF" for qty/name based on a given number.
if asm_mbr_name == "08457"
qtyqa="REF"
nameqa="REF"
else
qtyqa=rpt_qty
nameqa=asm_mbr_name
endif
My Question is, what If I have 3-4 numbers in my in the Region to REF
out? Can't seem to use if (asm_mbr_name == "08457") or (asm_mbr_name ==
"09887").
Elseif does not work. I've only ever had to use 1 name/type in the past?
Thanks - Robert Maillet
QuestAir Technologies
RE: Repeat Region Relations - AND/ORs
This worked ok. Set the values 1st, then only change the values based on
criteria.
qtyqa=rpt_qty
nameqa=asm_mbr_name
qtyqa="REF"
nameqa="REF"
endif
if asm_mbr_name == "08455"
qtyqa="REF"
nameqa="REF"
endif
if asm_mbr_name == "08442"
qtyqa="REF"
nameqa="REF"
endif
_____
