For the first one, if the data is from a dimension, merely changing the number of decimal places in that dimension's properties accomplishes this. If that's not the case for your problem, I'm not sure the first two are possible with 2D repeat regions.
The third problem, however, is a simple drawing setup file (*.dtl) option. Look for the option "2d_region_columns_fit_text" and change it to yes. Each column will be automatically sized to fit the text within.
Hi All,
I'm using a 2-D repeat region to display the contents of my family table
in a drawing. I've run across several things I'd like to do, but can't
seem to find a way. Is it possible to do any of the following?
- display different number of decimal places for each column's contents
- display a parameter description for the column heading or display
custom text rather than the parameter name (i.e. my parameter is A_DIA
and I want the column heading to be 'A' DIA)
- vary column widths throughout the table (I have one column
IDENTIFICATION STAMPING and another called ITEM NO. - I don't need the
columns the same width)
Hopefully my attached image is small enough to make it through.
Thanks in advance,
Tyler
<<repeat.jpg>>
