Repeat pattern on surface following a curve?
SOLVED
Re: Repeat pattern on surface following a curve?
Thank you john !
Your parts works well too ! What parameters have you changed so that the pattern features are merged with the curve quilt ?
There are 2 Pattern types, Standard Pattern type & Geometry Pattern. You selected Geometry Pattern which only patterns the geometry selected & not the associated merge feature too. Use a standard Pattern.
John
Thanks !
I am new to this forum it is very helpful !
This forum has saved me, more times than I care to remember. If I am struggling with something, its the first place I turn to for help.
John
