I want to insert some parameters in drawing.
I did for title. I inserted &asm.name
I just want to know the parameters for the following
drawing no.
revision
sheet no
Dhinesh
Sheet no. :
&sheet_number
&total_sheets
exp.
&sheet_number / &total_sheets
Calling on parameters defined in model is via &
exp.
& MODEL_NAME
Drawing name:
{0:&dwg_name}.drw
Dont quite understand drawing no. and revision? is that drawing parameter or what?
Sheet no. :
&sheet_number
&total_sheets
exp.
exp.
& MODEL_NAME
Drawing name:
{0:&dwg_name}.drw
