Reset position of Browser
Highlighted
Regular Member
I know that if I have "undocked" the Browser bar from the Creo Elements/Direct Modeling UI, I can drag it back and even snap it to a pre-defined dock location. I also know that I can turn the Browser on or off using the F12 key. What I'd like to know is if there is a way to have a command or shortcut to bring the Browser bar back to its default docked location (on the left side of the UI). The reason for wanting a command or shortcut is if I have moved the Browser bar to a second display and then undock my laptop so I no longer have that second display; in that case I have no way of dragging it.
Highlighted
Re: Reset position of Browser
Hello Peter,
try it with the commands:
(sd-undock-graphical-browser "parcel-gbrowser")
(sd-dock-graphical-browser "parcel-gbrowser")
Although that does not bring the "Browser bar" at the docked position but at least the "Structure browser" back to the window.
Set it with 2 screens so modeling can remember the position of the undocked "Structure browser" in the first window.
Tested in v19 m20
In Express 6, it does not work ?!.
