Righ Click No Dropdown Menu
SOLVED
Visitor
Hey guys,
Just start learning Creo. I now have a problem:
In the instruction, instructor does a lot of right-click, will have a pop-up menu, as shown below.
Mine will not show anything. Is there some setting?
How do I change my software? Or how can I define the angle between two lines? Thanks!
1 ACCEPTED SOLUTION
Highlighted
Re: Righ Click No Dropdown Menu
Remember to slam down the right mouse button at least for one second. There is a delay in the right-click menu. It does not come up as quickly as in any other Windows program.
2 REPLIES 2
It depends on which tab you have selected and if you have pre-selected any geometry or datums.
RMB is context sensitive so you will get different options based on what you have selected or not selected.
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
Highlighted
LiveWorx Call For Papers Happening Now!
