Rolling a Wheel on a surface using Mechanism
sarthakseth
I want to roll a wheel on a surface using creo mechanism. By using the pin connection, the wheel only rotates about its own axis. Please help. Thanks in advance.
Sarthak
1 ACCEPTED SOLUTION
sarthakseth
(To:psobejko)
Thanks for your reply. Your answer did help me to explore further possibilities using rack-and-pinion connection. However, I did find out a different solution to my own question i.e by using multi-level assembly.
In the first level assembly, I defined pin joint between the roller and axle.
In the second level assembly, I called the above assembly and created a sliding joint between the assembly and the rolling surface.
This worked out pretty well for me. I have attached the images for reference. Hope it helps someone lese.
Cheers!
Sarthak
I don't know the scope of your model, but here's an example of how you can "simulate" perfect rolling motion on a plane, using mechanism:
It relies on using a rack-and-pinion connection to establish a relationship between the rotation of the wheel component within the wheel+axle subassembly to the sliding movement of the wheel+axle subassembly component.
Creo 3.0 model attached...
sarthakseth
(To:psobejko)
Cheers!
Sarthak
