Rotary table support
Participant
Hi Gurus,
Couple of questions:
Does Pro/ENGINEER Production Machining Option ( which is for 3 axis milling)
support rotary table movement?
Also does anyone have a postprocessor for Fanuc 18M & 21M? Is Fanuc 21M used
for 5-axis machining?
TIA,
Niloy Guha
Niloy,
To answer your 2 questions: Does Pro/ENGINEER Production Machining Option (
which is for 3 axis milling) support rotary table movement?
It supports up to 4 and 5 axis positioning only milling (not simultaneous
milling) and 2-axis turning.
Yes, I have several posts, but you really have to know more than the
control. I can give you a really good deal creating them for you. I do
this for a living and will beat anyone's price to get you setup with post
processors.
Sincerely,
Kent Hanson
PostPro
Pro/NC and GPost Services
27011 Washington Blvd
Edwardsburg, MI 49112
T 269.663.5515
M 574.286.8145
_____
Kent,
Does that include me? 😉
Fred Nemecek
Austin N.C., Inc.
512/458-1112 x19
_____
Thanks to all those who replied. What I have understood is that PMO supports
4 & 5 axis positioning motions. But simultaneous rotation & machining is not
possible.
To further give clarity to my question I have attached an image of the part
to be machined.
My client is buying a Horizontal Machining Center which will be used to
machine a cylindrical barrel positioned vertically. There are 12 holes
patterned on the circumference of the barrel and there are 3 such patterns
along the length/height of the barrel. I hope I have been able to make
myself clear! Will PMO suffice or should they go for CMO in order to machine
this sort of part?
TIA,
Niloy Guha
Message from Brian Thompson (PTC General Manager and DVP) regarding Creo Business Continuity plans.
