Rotate assembly/view view with respect to current view.
vdevan
How can i rotate model with respect to the current viewing position.
lets say i am looking at the Front view, is there a way to rotate the view 90 deg to get the top view without having to select the Top view the view orientations.
Note : I am used to this kind of thing in SW and it was very helpful in viewing all possible angles using just arrow keys and Shift+arrow keys. i just want to know is it possible to do in Creo.
Thanks in advance for your answers.
1 ACCEPTED SOLUTION
StephenW
23-Emerald II
(To:vdevan)
Great.
For the 90° orientation, make a mapkey using dynamic orient. Go to the view tab, saved orientations, reorient, then you'll get a pop up orientation box, change the "type" to dynamic orient. Then you and key in orientation angles based on the axis you want to spin around.
10 REPLIES 10
dschenken
(To:vdevan)
You can dynamically orient a view and chose horizontal with a value of 90 degrees.
If this happens often you can capture a mapkey to make this move. Or create a mapkey that selects Top.
vdevan
(To:dschenken)
i am not an expert in creo, and I find it hard to understand ..
can you share any tutorial relating to this ..
StephenW
23-Emerald II
(To:vdevan)
You can't use the arrow keys like that in Creo.
You can create mapkeys to do what you want.
The link is a youtube video on how to create mapkeys.
There are also a lot of posts on creating mapkeys in the forum, many of which deal with view orientation.
https://www.youtube.com/watch?v=FWp_ASys8ZE
vdevan
(To:StephenW)
hey Stephen,
Thank you so much for the response.
I tried doing map keys, and could successfully create map keys.
i faced 2 problems,
1. It do not accept combination with Shift / Ctrl
2. I still cannot figure out a way to rotate my current view,  90 deg Right or 90 deg left.
am not worried about the first one , i need answer for second.
Thanks in advance.
StephenW
23-Emerald II
(To:vdevan)
Great.
vdevan
(To:StephenW)
Thank you a lot , that was helpful.
now is it possible to use in combination with shift / ctrl ?
StephenW
23-Emerald II
(To:vdevan)
I'm not sure what you mean by that.
Your mapkey for moving to the top view could be "tv" or "TV" (lower case or caps).
vdevan
(To:StephenW)
thank you got it cleared
dschenken
(To:vdevan)
Mapkeys are case insensitive and can only use Function keys and printable characters, so I think arrows and control combinations are not allowed.
vdevan
(To:dschenken)
Thank you
