How it’s made, extrusion die or other processes, any buddy guide?
kind regards,
ADNAN
Manish,
pattern quantity has its own dimension symbol. If you show pattern dimensions using Edit command and put mouse cursor on pattern quantity value (eg. 4 EXTRUDES), then after a while you will see a floating box containing the name of pattern quantity symbol (eg. p10). You have to add this dimension into Family table column.
I attached simple model created on Creo Parametric 2.0.
Martin Hanak
My solution is described on simply holes:
1. use pattern of datum axis like driving references. Make a pattern of 4 holes
2. place hole to this reference and make full reference pattern
3. place second hole to the same driving refernece. Press pattern and exclude holes that you don´t need. Click on black point and change it to white one.
4. make a family table, that include both HOLE PATTERNS and pick yes/no als you wish
l hope, it can help you...
Manish,
Martin Hanak
Hey Martin ,
Thanks A lot ,finally i got the answer ,this is great...awesome
Manish
