SUMMARY: "Could not intersect part with feature"....
Thanks to all who replied... the consensus was to adjust the accuracy. Seems this was required, I believe because the thin protrusion intersected itself. Essentially, and in 2d for this explanation, consider two 15mm diameter circles next to each other with a tangential distance between them of 5mm. Creating a thin protrusion with them of 10mm, making the wall go out as opposed to inward, and the two resulting protrusions overlap. This seemed to cause some ambiguity within pro/e. Once I moved them farther apart or changed the accuracy, everything was fine. Additionally, if I played around with things so that the thin protrusions did NOT intersect, everything was also fine. (Essentially, I cut the sweeps BEFORE creating the thin protrusion such that the result would be a single non-intersecting protrusion.) The quickest solution was to adjust the accuracy down a bit, the other solutions we what I found be doing some testing....
