SWEEP CUT IN CREO 2
rkadam
SWEEP CUT IN CREO 2
PLEASE TELL ME HOW TO SWEEP CUT IN CREO 2
CONDITION
OPEN SECTION &CLOSED TRAJECTORIES
FIND ATTACHED IMAGES
Rohidas,
probably, your model has long history. This means it was created eg. in ProE Wildfire 5.0 and you have opened it in Creo Parametric 2.0.
  • In ProE Wildfire 5.0, the feature Sweep Cut was available in User Interface.
  • In Creo Parametric 2.0, the feature Sweep Cut is not available in User Interface (user cannot create such feature).
If you edit existing Sweep Cut in Creo Parametric 2.0, you will get old user interface known from ProE Wildfire 5.0.
Martin Hanak
Martin Hanák
Steven,
you are right, user can cut material using Sweep feature in Creo Parametric 2.0. My previous response told Rohidas that the feature Sweep Cut known from ProE Wildfire 5.0 is not available in Creo Parametric 2.0.
Martin Hanak
Martin Hanák
