SYMBOL DRAWING
SOLVED
Amethyst
SYMBOL DRAWING
hello everyone, i have a question: is it possible to show an attirbute in a symbol in two different lines? for example: \MATERIAL\ has to be as follows MATERIAL ENGLISH LANGUAGE MATERIAL ITALIAN LANGUAGE thanks!
Re: SYMBOL DRAWING
I believe they would need to be 2 different attributes to ensure they are on two different lines.
Creo is an endless adventure: Always more to learn.
Re: SYMBOL DRAWING
Re: SYMBOL DRAWING
You will need unique parameters for each language, then you can specify which parameter(s) to use in the drawing symbol.
