Save from Wildfire to 2001-Summary
Newbie
It seems that the .neu file is the best way. The model try doesn't show
all the features so it looks like you cant work on the model in 2001.
Thanks for the help : )
I believe PTC originally stated that this functionality would be
incorporated as part of Wildfire. If so, the plan was eventually dropped.
Hopefully it will be provided in a future release. I believe the only
option available to you is to create an STL or Iges file in Wildfire and
then import it into 2001. The resultant model will be somewhat useful but
not contain full model functionality.
How to Use Pro/ENGINEER Wildfire Cross Platform Cross-Release
Interoperability
Description
