Search for an icon
SOLVED
Highlighted
Alexandrite
Search for an icon
Hello
In Creo 3.0 I have more the icon that allows to assign certain functions to
the piece under construction, or material, its units and others.
I remember his name to find it in the list of
functions that can be added in the menu bar.
Kind regards.
Denis
1 ACCEPTED SOLUTION
Re: Search for an icon
What about this ...
MH
Martin Hanák
12 REPLIES 12
Hello
No one is the name of this icon?
Kind regards.
Denis
I guess nobody understand your question .
MH
Martin Hanák
Hello Martin
It is both simple and difficult to explain.
When you start to build a new piece, in line with the function icons there is an icon, I do not have the name, when clicked it opens a window menu in the how we can define the material, units, and several other things.
Kind regards.
Denis
sounds like the model properties function; icon looks like a cube.
does this mean that you can launch Creo Parametric and then you do not know how to continue  ? Can you attach a picture of Creo window ?
MH
Martin Hanák
Hello
The icon in question to simply disappeared from the menu bar and I can't
simply not find general functions back.
I work with Pro E since version 13 and with Promechanica for Rasna.
Kind regards.
Denis
please attach a picture of your screen and mark the location, where the icon is missing.
MH
Martin Hanák
Hello
Here is the image with its position or missing.
Kind regards.
Denis
your picture shows default Creo ribbon interface in Part mode. Nothing is missing. If you had additional group on the ribbon right side in the past, then I am sure that Creo ribbon interface was customized by you or your administrator. This customization disappeared "somehow" and nobody at PTC Community will tell you what group and command was available in your ribbon. You have to customize ribbon interface by yourself - you can add new group into ribbon and add required commands into the group.
For example:
MH
Martin Hanák
