Good Day All,
To Set up a solid model for Centrifugal Loading. What elements are required.
I have done simplified beam/midplane analysis and now want to do a full 3D solid model analysis
on a non symmetric part.
Thinking of a wheel hub as an example.
Would anything else be needed other than fixing the hub hole with a displacement constraint in all directions,making sure the y axis is parrallel to the axis of the hub, assigning material properties andadding a centrifugal load repersenting the rpm the hub is spinning at?
Thanks for any help you can provide.
Don A
