Shell
Aquamarine
Shell
All,
Is it possible to shell multiple times in a part?
I am using WF4.0 currently.
I remember the days when you tell it what to shell.
I think since WF it shells the whole part and you subtract (remove
surfaces)
If I extrude, then shell, then add another extrude, then shell...it
picks the whole part.
I try to mess with it to no avail.
hopefully I am clear on this.
Anyone?
Nothing critical. Just looking into pet peeves between assignments.
WayneF
RE: Shell
Just saw this one....
One shell per part, my friend.
But, you could create the subsequent features as closed/capped surfaces, offset it, solidify the parent then use the offset to solidifly as a cut. You can do that all day long.
Shell
I have yet to post a summary on this. So far - a few responses like
yours with the exception of the offset and solidify options, which I
have used. This may be too much.
I guess it it be nice to shell more than once. This would be quicker
than a offset edge chain option.
There are reasons why it would not work well....in considering molding,
etc.
