Showing Part Simp Reps in a drawing
Hello All,
Might any know why I can't show a parts simp rep in a drawing?
Thank You In Advanced
Matt Romero
Mechanical Designer
Plexus Technology Group
361 Centennial Pkwy, Suite 300
Louisville, CO 80027
Re: Showing Part Simp Reps in a drawing
Showing Part Simp Reps in a drawingMatt,
You have probably figured it out by now, but to get a Simp Rep to show on the drawing you need to highlight the view, RM button, drag down to Properties, Select Drawing Models, then select Set/Add Reps. The list of Simp Reps will come up and you select the one you want to show in the view. This is how you do it in WF, but the process is the same for 2001 just different menu picks. HTH ...
Steve M. Wilson
Sr. Mechanical Engineer
Bivio Networks, Inc.
Pleasanton, CA
swilson@bivio.net
"Matt Romero" <matt.romero@plexus.com> wrote in message news:38888@draft...
Hello All,
Matt Romero
Mechanical Designer
This is true, but because of all the problems Simplified Reps cause in a
drawing, it is far better to create a family table.
Frederick W. Burke III
Mechanical Design Engineer
ISE Corporation
7345 Mission Gorge Road, Suite K
San Diego, California 92120
(619) 287-8785 x-151
Showing Part Simp Reps in a drawingI've never had any problems with Simp Reps. Setting up a family table to be able to suppress the display of certain objects in an assembly seems a lot more complicated, besides the fact that if you have more than a couple of indicies in your family table your regen time is going to get very long. I'd be curious to know why Simp Reps are not working for you. Please explain.
