Shown vs. Created Dimensions
Batman vs Superman (was Shown vs Created)
I use created when they get the job done, but don't hesitate to throw
created dims on a drawing when it's easier/faster/whatever.
I always had the feeling the Batman is a lot more vulnerable than
Superman - he's too human to beat Superman ... he IS human. Batman may
have cooler gear, but Superman doesn't need it.
wait ... it's only Tuesday!
hold this debate until Friday afternoon.
I'd never force anyone to do it one way or the other. As long as the guys in
the shop can make the part with the information on the print is all I
require.
John Neilson
CMC of Georgia
Engineering Dept.
2167 Highway 123
Toccoa, Ga. 30577
_____
RE: Shown vs. Created Dimensions
Don't ever use created dimensions unless it is something that is impossible with shown dimensions.
Another good time is when you are doing a casting drawing and you don't want duplicate dimensions for positions of holes and such with larger tolerances.
Why so serious?
Ask yourself this. What happens when we start using dimensioned and notes
on parts instead of drawings? Companies are starting to do it already, so
you mine as well get your engineers trained the right way.
Lance Lie
Sr. Tech. Support Eng. II
310.952.4347
310-952.4452 fax
"Dustin Neifer" <->
07/29/2008 12:43 PM
Please respond to
"Dustin Neifer" <->
To
cc
Subject
[proecad] - RE: Shown vs. Created Dimensions
That particular debate has been around the block too many times (search
the archives). We should consider arguing about this instead:
"Are driving dimension annotation elements better than driven
dimension annotation elements? If so then why?"
Dustin Neifer
General Dynamics Land Systems
"Tim Jabaay" <->
07/29/2008 03:10 PM
Please respond to
"Tim Jabaay" <->
To
cc
Subject
[proecad] - Shown vs. Created Dimensions
What is the general feeling about using shown dimensions? I was told to
always use them where possible from my first CAD administrator, but my
current admin doesn't like them. Just let me know if you like shown
dimensions or not and include your reasoning.
This is an e-mail from General Dynamics Land Systems. It is for the
intended recipient only and may contain confidential and privileged
information. No one else may read, print, store, copy, forward or act in
reliance on it or its attachments. If you are not the intended recipient,
please return this message to the sender and delete the message and any
attachments from your computer. Your cooperation is appreciated.
Wrong answer
Don't ever use shown dimensions unless you plan to inadvertently change
the design from the drawing.
(sorry could resist, no offense intended)
This has to be the most over-analyzed pro/e topic.
My opionion, and that's all it's good for, is us shown when possible and practical, use created when necessary. But, for the sake of sanity (and company profitability), don't make either a hard-fast rule that everyone must adhere to. The biggest mistake i have seen is when a company says all dimensions must be shown. Have you ever tried to detail a sheet-metal part without using created dimensions. It can be done, but it is a huge waste of time with 0 (ZERO) value added.
Have fun,
Steve
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
This brings up a a good point.
When you are eliminating the drawing for a part, what are the dimensions
that are displayed in the model? I would think that again, you could use
the model dims (shown equivalent) or created (similar to a reference
dimension).
Doug Pogatetz
Mechanical Design Engineer
Northrop Grumman Corporation
I seem to recall seeing, or hearing of a cad ability that actually allows you to create a dimension in a drawing and having it now be the driver???
I use show dimensions mostly but on occasion will use a created
dimension. One problem with created is the inability to apply GTOLS to
the dimension with hand typing a bunch of gibberish @[@]@[@]@[@].
