Sindgle step hole making operations & Automatic Ordering
Highlighted
Newbie
A. Sindgle step hole making operations
Is it possible to create only one NC sequence for a single hole containingStandard Drilling, Chamfering & Tapping with 3 different tools and cutting parameters? Currently 3 seperate sequences to be created. If this option is added, users can create all such 3 sequences with onetime selections of holes/Axes. it could be done by adding the additional pop-ups for Tapping & chamferring opertaions.
B. Automatic Ordering of NC Sequences
We usually create several NC sequences in a CREO/NC model tree, and the it will be the same order when we generate the NCL file.
In order to make the NCL file output user friendly, can there be an option to do the followings?
1. Minimize the Tool Changes
2. Minimize the Pallet Indexing
3. User defined output sequence
Message from Brian Thompson (PTC General Manager and DVP) regarding Creo Business Continuity plans.
