Community Tip - If community subscription notifications are filling up your inbox you can set up a daily digest and get all your notifications in a single email.
X
I swear I remember seeing that there was an enhancement in WF5 or maybe Creo 1 to allow you to sketch a series of lines, multiple open sections, and extrude that as a thin feature. They showed it creating a network of ribs in a plastic part.
I'm trying to do this in an internal sketch (a simple T) in an extruded thin and Creo 2 is giving me the same old ' multiple loops must be closed' error. I tried again with an external sketch and got 'Intersecting entities encountered in the section' and Creo refused to use the sketch.
Am I dreaming about these extruded ribs? If not, how do I do this?
-- This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
After playing with this tool I find it quite useful, but rather specific in application.
The open end points of your sketch have no bearing on the end of your ribs. Proe / Creo is going to extend or trim them at the side wall of the part. So, a 1" long line inside a 10" wide part produces a rib across the full 10". Conversely, a 10" long line over a 1" long part produces a rib only inside the 1".
