Speeding up a pattern?
ptc-2031591
1-Newbie
Hello, I'm going out on a limb here but here goes! Using Pro/E Wildfire 3 - I wish to pattern a Group of 5 extrusions all based from a reference sketch - The first pattern is a 180 rotate around an axis of 1 instance - this is required to create a copy of the pocket facing the other direction - Next these two pockets (now grouped) are patterned 160 times across a flat featureless plate using a direction pattern in 2 axes, 24 instances in one axis and 7 in the other. The problem I am having is this: - Approx 3000 features require generation and this takes upwards of 15minutes on my system, this isnt going to work for me! Is there any way I can simplify the pocket so patterning is faster? I'm getting desperate! I'd be happy to upload the part if only I had (or knew of) a server I could upload it to! Other notes: - I cannot reference pattern - option is greyed and I dont know why? - I cannot control pattern options to change pattern type (general etc), the option is greyed out. - I have tried copying and solidying then patterning but the regeneration fails, error 'Failed regeneration' Any tips would be greatly appreciated!
2 REPLIES 2
I would suggest looking at a UDF that creates all of the features for one pocket and then pattern the UDF feature. Secondly group patterns take the longest on regen than other types of patterns. Thirdly you force a read only on the features if you no longer need to modify them. Without seeing the model image, I could not suggest anything else at this time. Good luck Eric
HI... when I get something like this, I usually, make a copy of the surface/geometry to pattern, and them pattern the surface-copy. Like this the pattern regeneration time will be significantly reduced, in the end just make a solidify to the first copy and ref-pattern it... hope this helps.. Cheers... Olavo
