Style curve drag handle dimensions
SOLVED
Participant
Hi everyone,
I'm currently using CREO 3.0. I can't show drag handle dimensions for a style curve on surface by clicking edit. I have to edit definition of the style feature. It would be nice if those dimensions could be shown and even used in relations. Does anyone know if this can be done in later versions of CREO?
Thanks!
Tags (1)
Re: Style curve drag handle dimensions
Hi, I am on Creo 4. I was never on Creo 3 but I believe it should work the same. To allow editing dimensions outside style feature, you need to check the box next to it during definition. See the snapshots below:s1.jpgs2.jpg
Is this what you are trying to do?
Awesome thanks!
