Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Summary - Relations evaluated on one instance only
Thanks to Robert for this suggestion, which worked perfectly:
Not totally sure if this will work, but you could try writing a relation (feature or part) something like:
IF REL_MODEL_NAME == "name of instance you want to drive"
d# =
ENDIF
and then fill out the rest of the instances in the family table. I would think this should only drive the one instance.
I added an ELSE statement to drive the other instances by a different relation.
Very nice, thanks again.
Doug Schaefer
Since the list likes hints from Joel <joelonsoftware.com>
Write the comparison as IF "name of instance you want to drive" == REL_MODEL_NAME That way, if you mess up and type = instead of ==, you get an error rather than an incorrect assignment that can be very difficult to find.
