Summary: relational pattern
Newbie
Thanks for all your responses. There are several articles and even some
stuff in pro/e help files on relational patterns. I had experience on a
flat surface, with the first point defined on a curve as actual length, as
described in the link below (profilesmagazine), however, the part I was
using was a projected square on a cone, so I could not measure the lengths
of the sides. (If you have the behavioral modeling module, you can measure
the length and then define it as a feature to use in your pattern) Without
behavioral modeling module, I was forced to do the following:
Create four separate curves on the cone and create four separate patterns
with the first point defined as length ratio. It's a little more tedious,
but not real bad. Figuring out the relations is pretty easy and entering
the increments is as follows:
MEMB_I=.25 or something like this...
MEMB_I=1/(holes-1)
If you want to know more...go to the profiles magazine link first. I
followed that exactly, except now I am defining the point on the curve as
length ratio and I am defining the axis as PNT ON SRF (point on surface).
Also, the original curve has to be defined as projected, follow surface.
Thanks again for your responses,
Jeff
HYPERLINK
"http://www.cadquest.com/articles/art5.htm"http://www.cadquest.com/articles/
art5.htm
HYPERLINK
"http://www.profilesmagazine.com/p20/tips_holes-pg1.html"www.profilesmagazin
