Sweep Surface Question
ArekTRI
Hi Creoes,
I have a question how to create a surface using only 2 splines - one for shape and other for trajectory?
It is possible in other CADs but Creo.
Thank you,
Arek
Creo 3 user
using sweep options you can create geometry whose sections are not perpendicular to the trajectory.
Martin Hanák
I uploaded test model. Look at it.
Martin Hanák
Hi @MartinHanak
Really helpful attachment.
Another issue (for me) is, Sweep command forces to create the perpendicular section to the trajectory line/spline what gives a different result.
In SW/Onshape or different CADs, it is possible. Onshape below.
Anyway, thank you very much.
Arek
Creo 3 user
Martin Hanák
Hi @MartinHanak
Thank you,
Arek
Creo 3 user
