Syntax Highlighting for Pro/Program and Relations.
Newbie
Does anyone know of an Editor that I can customize to syntax highlight
Pro/Program and Relation files? My company does a lot of Pro/Program work
and I think something like this would improve our productivity greatly. If
we used Linux I could get this to work with Nedit. However, we
unfortunately use windows 2000 (near future XP). I need an editor that will
work with windows 2000 and XP.
Cheers,
John R. Suyes III
Design and Development Engineer
Hill Phoenix
1925 Ruffin Mill Road
Colonial Heights, VA 23843
13 REPLIES 13
Re: Syntax Highlighting for Pro/Program and Relations.
I haven't tried it myself in XP, but Emacs is great for syntax
highlighting. Check out http://www.emacswiki.org and
http://www.gnu.org/software/emacs/windows/big.html
I bet if you dig around enough, you can find an Emacs config file that
sets up syntax highlighting for you.
Tim Lloyd, Aerospace Engineer Phone: (206)254-0880 x46
Blue Origin, LLC. FAX: (206)254-0581
13 S Nevada Mobile: (206)853-9209
Seattle, WA 98134-1121 Email: tlloyd@blue.aero
RE: Syntax Highlighting for Pro/Program and Relations.
Next to Halo, www.jedit.org is the best program ever.
Roger
Hello John,
PFA guideline for Pro/programme for your ref.
Hemant
I've wanted to use Emacs to edit relations for a while. I could then make a "mode" that formats relations so things are easy to see, do automatic indentation, etc. Unfortunately, I could never figure out how to get the relations data into Emacs from within Creo. There's no "file" to pass to it for editing, at least nothing that I could find. I gave up on this dream years ago and it still annoys me, especially since I've been doing a huge amount of relations editing in the last couple of years.
Try using notepad++ from https://notepad-plus-plus.org/
You can create your own "language" for the Relations and Pro/Program tools.
If you search these community pages, you may find some languages already defined.
Dan N.
Does anybody have a Notepad++ UDL for Pro/Program??
Regards, Steve
I've been asking about using Emacs for relations editing for a long time. I have never been able to get it to work. The problem seems to be getting the program to start up and be "fed" the file that is being edited. If I could figure out how to bring up Emacs with the relations, I could easily put together a mode file that would do syntax highlighting (colors for functions, key words, comments, etc.) It would be very nice, because then you would also have all of the wonderful editing functions that Emacs provides.
Other than that, I've also seen a lot of discussion of using Notepad+ to edit, with syntax highlighting possible.
As for Linux, unfortunately Creo long ago abandoned support for Unix-based operating systems, due to the fact that it's a tiny portion of the market and Windows is so dominant.
@seckart
Take a look here: UDL for Creo Parametric
You could try TextPad (Helios Software Solutions). It's my favourite tool for java programming, with excellent syntax highlighting features. You can use your own customised syntax definition file.
Here is the result of a quick experiment I tried after reading your post ...
I only tried this quickly for an *.als file.
I think I'll look in to this further for my own benefit.
Thanks for posting.
