TOLERANCE TABLE
Newbie
TOLERANCE TABLE
I was asked this question by a co-worker and we don't know
It is set to "general" and we can not modify the tolerances, we switched it
to "none" and we can. Is there a config.pro or XXXX.dtl file setting we
looked and could not find one.
If you know, please reply.
Gary L. Stasienko
Philips Medical Systems (Cleveland) Inc. Ohio USA
MRI Division, Mechanical Engineering Group
595 Miner Road
Cleveland, Ohio 44143, USA
E-mail: -
Re: TOLERANCE TABLE
still silence from PTC sideSmiley Sad...
probably thousands of users will be changing tolerance table to "none" manually forever...I admit Creo4 did progress on tolerances but this behavior is still there.
Really no config.pro option?
Re: TOLERANCE TABLE
I do... and probably forever, yes.
These should be hidden in hole tables.
Meaning if you have a different standard than -The- standard provided by PTC (yep, said in one mouthful!),
...you can make the changes there and use your specific defaults instead.
Re: TOLERANCE TABLE
I think the system works as intended.  I suspect your start part is defined for using ISO tolerance class (Fine, medium, coarse, etc).  Change it to use the ANSI standard and you will not have the issue...  (via model properties):
