TRIM_TOOLPATH_ON_HOLDER
jharper
I have a Re-Roughing sequence (of a .750 ball nose Re-Rough) with a .375 ball nose. The parameters of the tool are properly defined, including the holder parameters. I also have the parameter "Trim_toolpath_on_holder" set to "yes" and "Holder_Clearance" set to ".035". With all known parameters properly defined, the holder still gouges into the reference part.
Am i missing a parameter? Or is this a problem i should submit to PTC?
0 REPLIES 0
