I am creating a pattern of holes with "table" definition.
As soon as I define the table pattern, it is not allowing me to edit the definition of the pattern head hole.
I mean, if i have created the table pattern of the clearance holes, and now I want to change them to tapped holes, then in that case, table pattern doesn't allow to alter the hole type.
Is there any solution to this?
Sachin
The problem lies in the fact that when you change the hole type, it deletes the original and replaces it with a new hole. That means the pattern references no longer work. Serious oversight in the hole feature on PTC's part but I am certain it works to specifications. This is true with axis references as well.
