Table driven from parameters
lzanettin
I need help on tables.
I'm doing a template.
I need to have a table driven by parameters.
I mean:
I imagine a parameters "nbr of lines", (5 for example)
and my table is created with 5 lines.
is it possible?
repetition region??
thanks,
Laurent
Laurent,
a table in a drawing is dynamic in case that it contains repeat region, ONLY. Typically, a repeat region is used to show assembly BOM.
Martin Hanak
Martin Hanák
OK,
we ever use repeat région to show bom.
but now I need everything else.
I Need to do a template without any link with 3D model.
that will be a cabling assembly,
THe goal is to fill many parameters, and these parameters are called in tables.
in our cabling we can have from 1 to 5 connectors.
and I want to have in a table some details about these connectors.
SO, I need that my table automatically create 1 to 5 lines (I CAN create à parameter to drive the number of connectors)
Is it possible?
laurent
Laurent,
it is difficult to understand what you mean. Please upload some pictures and Creo file, if you want to continue the discussion.
Note:
If you can create requested repeat region for your cabling assembly manually, then you can save the table containing repeat region on your local disc. Later you can load this saved table into your drawing format or drawing template.
Martin Hanak
Martin Hanák
