Template_External_Involute_Gear
This is revision 01 of my gear template
Please read comments below:
/*PARAMETRIC MODEL FOR A TRUE INVOLUTE PROFILE EXTERNAL GEAR
THIS TEMPLATE HAS NOT BEEN FULLY CHECKED, HENCE ERRORS MAY OCCUR
                          ***** USE AT YOUR OWN RISK  *****
  • CREATOR OF THIS TEMPLATE  TAKES NO RESPONSIBILITY FOR ANY DAMAGE, ERROR OR ISSUES WHATSOEVER THAT MAY BE A RESULT OF THE USE OF THIS TEMPLATE
  • PLEASE NOTE THAT FOR CONFIGURATIONS WHERE UNDERCUTTING OCCURS, ACTUAL UNDERCUT PROFILE IS NOT GENERATED!
    IT IS ADVISABLE TO MAKE YOUR GEARS WITH NO UNDERCUT
  • ProProgram CODE IS USED FOR SUPPRESSING/RESUMING SOME FEATURES BASED ON INPUT PARAMETERS
For any errors or malefunctions, please let me know!
Re: Template_External_Involute_Gear
How do i input values? im on version 5.0
