Text marking printed on part
ptc-3074892
This is not a note, but actual marking on a part represented by text generated in the part file. Text needs to be modified.
Chris, Could you please elaborate your question as this does not make sense. Vimlesh.
CBenner
(To:ptc-1972305)
If you mean an embossed text on a part, look for the feature and edit the text within the feature's sketch.
Chris Benner
Autodesk ® Expert Elite
Thank you Chris. it is defined as a cosmetic ID in the part file, and in the dwg file, it is called out as an interface label. I'm guessing I'll need to modify the text in the label file.
Actually you need to modify the Cosmetic feature in the part file which will update the drawing also. -Chander
Do you mean the cosmetic feature in the part file of the piece part on which the label is affixed? I have tried to right click on the cosmetic id in the tree, and both edit and edit definition would not allow a mod of the text. Am I missing something?
