Through thread in part
Ketan_Lalcheta
Hello
I have created a tapped hole in Creo part file. Once I go to edit definition -> Shape, I am able to find option for through thread. Option is disabled for me. Any idea how to enable the same?
Thanks and Regards
Ketan
1 ACCEPTED SOLUTION
That may be due to "Upto Surface" depth that you have selected for the hole. As I know you can't make the thread depth and the hole depth dependent. Thru Thread is enabled only for a Thru All hole.
5 REPLIES 5
Hi, You're looking in the wrong place. See attachment. Use the pulldown for up_to_next or Through_all etc
Hi, Thank you for response. Actually what you have mentioned is for hole depth. I am looking for through thread depth. In other words, Suppose I have selected surface such that depth is 200.Now, I want 200 as thread depth.I can provide value as 200 for variable option, but how to achieve 200 as Through Thread? Variable I guess will not increase thread depth if reference surface used for through hole depth is updated.
see attached
I am not getting that option enabled.
