Tips for text
Tips for text
Here's an open discussion for text and notes in Creo and Pro-engineer.
Add tips and tricks that you know and ask questions that would be a good addition to this topic.
If you know of any previous threads that will compliment this topic please provide us the link.
131 REPLIES 131
Re: Tips for text
GD&T
• Use parametric GD&T when you can, and try this if you want to create a custom note.
Type this as the text:
And get this as the note:
• Notice that you type @[ before the symbol and then type @] after the symbol to create a box around it.
Re: Tips for text
Superscript
25 ft@+2@#
Notice that @+ goes before the text to be superscripted, and @# goes after.
Subscript
C@-6@#H@-12@#O@-6@#
Notice that @- goes before the text to be subscripted, and @# goes after.
Re: Tips for text
Multiple formats within single note
To edit the style of one section of a note, first click to select the entire note, then click again to select just the section you want to change. You can then RMB -> Text Style... and change size etc as required.
This works directly with separate lines within a note, but to change just one part within a line you must first separate that section by adding {1: and } around the relevant text:
{1:Large Text} Small Text
Separate Line
Then close the note editor and proceed as above.
Re: Tips for text
Hi Kevin...
The links didn't seem to work. I know what they're supposed to show... but they're not showing!
Re: Tips for text
What links?
Re: Tips for text
Superscript and subscript examples didn't pop up... and they didn't appear as graphics. Although in your previous message the GD&T stuff DID show properly.
Re: Tips for text
Now I see what you mean, the images are not linking to larger images. I'm not getting the options for Delte or Edit on that post (but, oddly, those options are available on the GD&T post) so I'll insert them here. Thanks Brian.
Re: Tips for text
Next you should cover other nifty tricks like overriding dimensions with special text, displaying dimension symbols (instead of values) for tabulated drawings, and methods to import true type fonts for use in drawings.
Oh yeah and also show how to do a superscript over top of a subscript (as if you're showing a limit or plus/minus dimension)!
I'd do it... but I'm lazy. And I'm behind on my presentation!
Re: Tips for text
In addition to KevinBradberry tip:
Add superscript first and then subscript.
