Tips for text
Re: Tips for text
you can create a symbol with an attribute and add it inside your note using the context &sym(balloon) and when you exit note creation, it will ask you to fill in the value of all symbols in the note. If the order isn't right, you can edit the attribute of the individual symbols.
Re: Tips for text
You can create a rule for your layer where you look for Drawing Symbols with Name == symbol_name*, make sure the rule is Associative using the Options Drop down, and then hide the layer.
