HOW TO CREATE A COMPLEX COIL IN PRO ENGINEER WILDFIRE 5.0. BY USING HELICAL SWEEP, WE CAN CREATE A SIMPLE COIL. CAN WE CREATE A ANOTHER COIL ON FIRST COIL.?
PL. GUIDE ME ON THE ABOVE ISSUE
REGARDS,
VINAY PATEL
You will have to create a curve normal to the surface where your coil ended. If you want to make a complex coil following a curve you will first need to make a variable section sweep, then you can make a sweep blend after that. I have attached a picture of a bent coil. Is this what you are trying to do?
See the thread about twisted wires. you'll need to use a VSS (Variable Section Sweep).
http://communities.ptc.com/thread/32022?tstart=0
F
