Tolerance Stackup
sgupta-2
Tolerance Stackup
Is this possible to stack up of tolerances of dimensions in assembly?
Sajjan Kumar Gupta
Hey Sajjan,
Check in the help files for using "Dim Bounds". I think this is what you need to perform your stack up.
Buddy
Sajjan Kumar Gupta
Did Bryant's suggestion help resolve your question? If so, please click "Correct Answer" next to the corresponding response. If you resolved this on your own, post the resolution details and then mark your response as "Correct Answer". Marking "Correct Answer" is a vital component to the efficiency of PTC Community; it not only lets informs users currently helping you with the issue that it has been resolved, but it also helps future users when searching for a resolution to this issue.
If your question remains unresolved and you haven't moved on, provide the community with an update post with more detail to help gain traction with helping you.
