Trace sketch image problem
SOLVED
Guest
I'm trying to trace an image in creo. But when I import the image, the image appears to be in this distorted patterned layout. The right image is what I want to import. Does anyone know what's wrong?
Image is in PNG
1 ACCEPTED SOLUTION
Re: Trace sketch image problem
@nwb10
ok, with this option slight delay is expected...  in that case you may need to check the machine details at https://support.ptc.com/partners/hardware/current/support.htm
Possibly this is not a supported graphics card to work with Creo.
You may try below options, instead of earlier one.. if that helps.
 enable_opengl_fbo no
enable_opengl_vbo no
enable_opengl_shader no
5 REPLIES 5
@nwb10
Image attached to post is working for me correctly.. possibly a graphics issue. Try setting config option graphics as win32_gdi
That solved the problem! However, I also noticed some lag.
I did some searching and apparently win32_gdi does not use graphics card? I'm running a GTX1050 and it is up to date, do you happen to know which settings I can tweak to resolve the issue? Currently all settings are at default.
@nwb10
That solved my problem completely, appreciate the help!
I had same issue after updating graphics card.  Had to revert to older version.
Creo is an endless adventure: Always more to learn.
