Trouble during Extruded Cut
mechanical
6-Contributor
Hi everyone,
I want to split one part into two using creo. I aimed for extruded cut to do so. When I sketch and press extrude, the extruded cutting option remains inactive. It could not be selected. I would be very thankful if anyone helps me out with this.menisci.JPG
1 ACCEPTED SOLUTION
You need solid or geometry before you can make a cut. Facet geometry is neither solid or surface.  You'll need to uise something like the Reverse Engineering Extension to make solid or surface geometry out of your scan data first.
LinkedIn
4 REPLIES 4
Facet geometry is special kind of geometry, you cannot combine this geometry with standard Creo features.
I am not sure what to do ... maybe you can save your part as shrinkwrap and apply your modification in this new part.
Martin Hanák
Thank you
LinkedIn
mechanical
6-Contributor
(To:dgschaefer)
Thank you for your reply. I did it using geomagic studio 12. I simply removed the things which were not required in the point cloud data that I obtained from 3d scanning.
