Hi
Our
designers want to add a new hole/thread: 1-3/16-18 UNEF.
Can you
explain how to do?
I found the
file UNF.hol but I don't know how to add new threads in it.
you have to create a new .hol file and place it in the folder with the other .hol files
check the attached. It is for a UNJEF-3B. I do not have a UNEF spec as we do not use them
you can adjust it as needed - just use the machine handbood to adjust the values needed.
....and you may want to look at this too
Has anyone got an explaination on the headers in a hole file?
