Unable to save printer configurations
SOLVED
BWS
Bedrock
The option to save my printer configurations is not available. How can I enable this option?
See picture:
Re: Unable to save printer configurations
See picture:
unfortunatelly I do not have 5.0.1.0 installed.
In 5.0.4.0 in Drawing mode I click File > Print and then Settings > Save Settings
Martin Hanák
25 REPLIES 25
please provide info about Creo version you use.
Martin Hanák
Version: 5.0.1.0
See picture:
Martin Hanák
Thanks alot!
Do you remember if it is the same in Creo 4.0 M040?
No I don't know, you should try to make a drawing and go to "PRINT", from there you should be able to save it.
The menu looks the same on Creo 4. Go to print, then you can make your settings, then you push the drop down arrow as shown in Martin's screenshot to save.
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
Stephen,
Since you have the knowledge about these things.....
Do you know if it is possible to create a file that export all combined views (with a format) as 1 pdf file to a default dir?
I don't know what "combined views" are.
If you are referring to all sheets of a drawing, in the print ribbon, select the settings button, then there is a sheets  options to select All sheets.
Steve Williams
