Do you know where I can find this option?
allow_3d_dimensions YES
Thanks:D
edit: found it!
Thanks:D
edit: found it!
https://support.ptc.com/help/creo/creo_pma/r6.0/usascii/#page/detail%2Fdetail_options.html
https://support.ptc.com/help/creo/creo_pma/r6.0/usascii/#page/detail%2Fdso_customize.html%23
Thanks!
Only problem now is, I want only the dimensions per combined view that I manually added myself. Not all the model dimensions that are automatically added.
@BWS wrote:
Thanks!
when you start model dimension adding, dialog box is displayed. In this dialog box you can see the list of dimensions and check boxes in front of them. Therefore you can select what dimensions will be added to the view.
Do you mean dimension adding on the drawing, or on the 3d model? Because I don't get this option to check/uncheck dimensions when I am adding them to the model. I can only check/uncheck dimensions after clicking on "Show model dimensions".
I mean dimension adding on the drawing. Please next time attach picture to describe your problem.
Upcoming October 2019
Regional User Groups
