Unable to save printer configurations
SOLVED
Re: Unable to save printer configurations
A combined view is just another tab below the 3D model with its own orientation / simplified rep, annotations etc.
I only print from the 2D drawings so I can't help with that problem, sorry.
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
And what views do you print normally? only front, left, right sides?
Or is it possible to print a isometric view with annotations on it?
what about uploaded example.
Martin Hanák
Hey,
Did you get that .pdf by using a .pcf file?
Because that output is the thing I am looking for, but I don't want to go through all the options for every part.
If so, could you upload the .pcf file?
@BWS wrote:
Hey,
I created PDF file using Save As command.
Martin Hanák
Well, I am looking for an option to add a format to it (logo, partname, weight etc.), and hopefully all with the press of one button.
Thanks anyway though:)
no problem ... if I want ... I can add drawing format to my test drawing sheets.
Drawing format can contain logo, partname, weight etc.
When I am finished I simply use Save As command and I have PDF file in single step. To simplify PDF creation I can define mapkey.
Martin Hanák
Could you tell how you get the dimensions on the combined view, on the drawing?
Try it in my drawing firstly, then in your drawing.
Drawing must have following option set:
allow_3d_dimensions YES
Martin Hanák
