User defined feature parameter
Participant
Hi everyone,
I have a part model template. As I work on the model, I add user-defined parameters for the features. Is there a way to have this feature parameter automatically added when features are created so I don't have to create it every time?
Currently I have to click in my user-defined parameter column of the model tree to create the parameter for each feature. It would be nice if it was already in there so I could just edit it.
It would save a few steps each time. It's also annoying how you have to hit OK after adding the parameter and then still have to hit ENTER.
Dave
Re: User defined feature parameter
You can create the coordinate system with the note being variable as a UDF. When you add the UDF you will have the option to fill in the value for the note parameter. It will be added as a group feature that can be ungrouped.
No this has nothing to do with a UDF. I posted that pic to show how the feature parameter is filled in for each feature. I want that parameter filled in automatically for each feature as it's created.
Creating it as a UDF does that; it groups the note parameter with the coordinate system. The note can have a single value or it could be variable. There would be some setup involved but its possible you could even have the parameter setup as a restricted value parameter so that the user selects from a list of values rather than typing in a value.
