Using Parameters in commands
MohaSharifi
6-Contributor
I want to define parameter for number of members in pattern, can anyone know how?pattern numbers.png
6 REPLIES 6
Make your patterened feature and then set a relation to drive the pattern number from a parameter.
Thanks Gary
Moha,
If you right-click, edit the pattern feature, the number of pattern members will show up as one of the editable items.
and you will see the names of the dimensions. The number of pattern members in each direction is always a 'pxxx' number, p301, or p12, or something like that.
In a drawing, you can use that number directly in a note by typing '&p12 holes ...etc.'.
The problem comes when your pattern has more than one direction. There is no single parameter for 'p1 + p2'. If you want a parametric note in yur drawing for the total number of holes in a p1 x p2 pattern, you will need to create a parameter no_of_holes in the part and use a relation to make no_of_holes=p1+p2.
Conversely, if you want to use a parameter to drive the number of holes in a given direction in your part, make the pattern and identify the 'pxx' number as before, then make a parameter I_want_this_many_holes in your part and use a relation to make p1=I_want_this_many_holes.
See also:
http://communities.ptc.com/message/240055#240055
and
http://communities.ptc.com/ideas/3639
I hope this helps.
John
MohaSharifi
6-Contributor
(To:JWayman)
Thanks John
The answer is that you cannot do this directly, but the value in your image can be driven by parameters and relations. It just requires a separate step to manipulate this value.
bduncan
(To:MohaSharifi)
