Hi everyone,
I am wanting to do a variable chamfer but I don't think Creo has that feature as yet.
So I have tried to use the swept blend tool instead. However it's not following the path I want. I want the section sketches to follow the edge of the part.
Picture below shows three sketches and path
How do Stop the cut from curving away?
If it's possible to used the chamfer tool it would make life a lot easier.
I try to get smartest chamfer with less control curves. Try to see if it can be useful
It's better for me if you post the part and we can work on it.
Chamfer variable on a edge doesn't exist in Creo, but you can do multiple sets of chamfer feature in order to change value changing edges.
Hi Mauro,
How do I upload cad file on this forum, I see you can upload pictures and movies but no files. Maybe I'm missing something here?
regards
Tom
After pressing REPLY to a message, go to ADVANCED EDITOR.
There in the right corner above you find ATTACH bottom.
Hi Mauro,
Thanks for your help Mauro and answering my question. looks great!!
Tom
