I'm trying to create a part like the one in the attached image. I created this with multiple protrusions.
I have not been able to create it with just one protrusion.
I'll give anyone an at-a-boy/girl (or maybe just a thank you)if you can show me how to create it with just one protrusion.
I got it to work but not precisely the way I want.Thanks for all the help.
I think the biggest issue was that I was not using multiple sections as suggested by a bunch of people.
So I split the "Origin" trajectory to match the number of segments in the "Secondary" trajectory which aloud me to use multiple sections. But as you can see in the attachment, it does not follow the "Secondary" trajectory very well.
What am I doing wrong?
At-a-Boy Mark! And thank you.
It would seem that the best way to do what I want is using boundary blend. This gave me a nice smooth surface that I can work with to create a solid from. You can see the resulting surface in the attachment.
I used four curves for the first direction chain collectors that define the shape from a circle and going up to the octagon. Then I used the four "patterned" curves to get the revolved hourglassshape.
Thanks to everyone who replied. Most of them where very close but I like this method.
Here is the file for those who are interested in how the part was created.
Personally I'd go for revolve then blend, the revolve gives you precise control over your section, with any blend you have to accept the system generated volume between the sections- see attached. Swept blend surfaceis set tangent into the revolve
Internal sketches and planes on the fly, this is a more concise, predictable model,
Sean
